Author Topic: Schema's stored on read-only artifacts can still be changed  (Read 6320 times)
Details:
Schema's in the schema composer can be stored in artifact elements.
When that artifact element is in a version controlled package that is checked-in, the artifact is supposed to be read-only. Unfortunately EA doesn't stop you from changing the (read-only) schema.
Steps to Reproduce:
- Create a version controlled package
- Create a new schema and save it on an artifact in the version controlled package
- Check-in the version controlled package
- Open the schema in the schema composer
- Change the schema in the schema composer, and notice that EA doesn't stop you.
Reported
Re: Schema's stored on read-only artifacts can still be changed
« Reply #1 on: July 14, 2022, 03:34:45 am »
Again... you know.
