Author Topic: XML transformation generates a missing protocol prefix exception  (Read 6990 times)
Kamal Hammoutene
Hello
I have the following exception when I try a basic XML/XSLT transformation (EA 16.0.5 trial version). I have attached the package XMI.
I have (almost) followed the procedure described in https://sparxsystems.com/enterprise_architect_user_guide/14.0/model_domains/model_an_xsl_transformation.html but created the XML file and XSLT file objects directly in EA.
Adding that, even though I enter the XSLT code via the EA GUI in the XSLT file object stored document, when I try to export that file object, the exported file is empty.
Thank you for your help.
[384102621]      Stack recording threshold set to 3 frames
[384102828]      Debug XSL Transformation
[384102828]      Using XSL stylesheet: C:\Users\ADMINI~1\AppData\Local\Temp\EADocs\BF70A65D-5B48-4de5-9436-8B0FEDE92C89\Xslt1.xsl
[384102828]      with XML input: C:\Users\ADMINI~1\AppData\Local\Temp\EADocs\25C226D7-203F-4082-87E0-D142819ABAE4\XmlFile1.xml
[384102829]      Default Directory is C:\Program Files\Sparx Systems\EA Trial
[384102829]      Agent dll found: C:\Program Files\Sparx Systems\EA Trial\vea\x86\SSXMLAgent32.DLL
[384102829]      Debug Session Started
[384102829]      Agent: Started
[384102935]      arseException: missing protocol prefix,
[384102957]      Debug Session Ended
[384102957]      Shutting down
I didn't find a way to attach the XMI file to this message so I could send it if needed.
« Last Edit: July 20, 2022, 12:26:40 am by Kamal Hammoutene »
ValmyEA
Re: XML transformation generates a missing protocol prefix exception
« Reply #1 on: October 18, 2022, 06:01:39 am »
I have exactly same problem
« Reply #2 on: October 19, 2022, 03:31:00 am »
You should both report a bug. See Support page down below.
ValmyEA
« Reply #3 on: October 20, 2022, 08:03:31 pm »
Done no solution for now.
« Reply #4 on: October 20, 2022, 08:21:33 pm »
Probably because of the
arseException
Honi soit qui mal y pense
ValmyEA
« Reply #5 on: October 22, 2022, 05:43:40 am »
Just for information :
- Trial Edition : not tested
- Enterprise Architect v16.0.1605 - 64 bit  => not working
- Enterprise Architect v16.0.1605 - 32 bit : ok !!!!!
I have installed  with this sequence :  Trial Edition(x64 ? ) =>   Enterprise Architect  64 bit =>  Enterprise Architect  - 32 bit
