Author Topic: Generate Sequence Diagram set-up for C# using Unit tests  (Read 2254 times)
TerryWatts
« on: August 07, 2022, 02:17:44 am »
Plan: I want to set up EA to record Sequence diagrams from a unit test. I figure this is a direct way to a required sequence.
Any help would be greatly appreciated. Test Framework is MSTest, although I could change that I guess.
If someone can help me with this it would be GREAT!! :).
Currently I am trying to set up the Execution Analyser:
Build/Build:  MSBuild C:\Dev...\My.sln
        /Clean: devenv C:\Dev...\My.sln /Clean
Test/Test: vstest.console.exe test.dll
Debug/
    Platform/
       Debugger: MS .NET
       Default dir:  Project dir
    TracePoints:
       Output: Screen
    WorkBench  ??
Intellisense ??
Run
    /Run
        Run: vstest.console.exe tests.dll --tests:<test Class name>.<unit test name>
        Exec Command line: Process
         Default dir: ..Debug\net6.0
Deploy: ??
Recording: ??
Simulation: ??
