Author Topic: Adding a Sub business process diagram into a report  (Read 2776 times)
gcoleman0828
« on: August 09, 2022, 05:17:11 am »
I am creating reports from an existing package which contains various business process diagrams. These diagrams has sub processes in them that I would like to reference in the PDF output. I see that I can output anything in a package but was wondering if it is possible to create a report that includes multiple packages. I am looking to do this because I have these sub process diagrams (common that is done over and over) in higher-level packages further up the tree in the same Model.
I could just include the whole model, but then the document will have more diagrams than necessary. Even if there is a way to cherry pick diagrams into a report, that would be sufficient.
Gregg
Sunshine
  • Its the results that count
Re: Adding a Sub business process diagram into a report
« Reply #1 on: August 09, 2022, 12:42:14 pm »
You can indeed choose multiple packages to include into a generated document by creating a model document and added them to the model document. See documentation on publishing reports for more details.
https://sparxsystems.com/resources/user-guides/16.0/publish/document-reports.pdf
Each diagram also has property dialog which has an option to exclude image from documentation.
Diagram>Document Properties>Exclude image from Documentation.
Happy to help
gcoleman0828
« Reply #2 on: August 12, 2022, 06:23:44 am »
Awesome Sunshine. Appreciate it. I will read through the documentation provided.
Have a great weekend!
Gregg
