Author Topic: v16 - Metatype attributes for Connector shapescripts  (Read 4128 times)
« on: August 09, 2022, 04:18:07 pm »
In the help for Display Element/Connector Properties, we find:
  • source.metatype                      for details of these four source.metatype properties; see the
  • source.metatype.general               Define Metamodel Constraints Help topic
  • source.metatype.specific
  • source.metatype.both
(with the equivalent target versions).
Unfortunately, while the Help defines these, it doesn't describe the values returned and how they may be used in a shapescript.  Can anybody enlighten us on these points?
TIA,
« Last Edit: August 09, 2022, 04:20:30 pm by Paolo F Cantoni »
Re: v16 - Metatype attributes for Connector shapescripts
« Reply #1 on: August 09, 2022, 07:07:20 pm »
I seem to remember having seen a page with those values. But I forgot where. Probably it's needed to wait for a Sparxian coming back from holiday...
Takeshi K
    • Sparx Systems Japan
« Reply #2 on: August 10, 2022, 10:42:05 am »
Hi all,
As Paolo quoted, it is described in the Define Metamodel Constraints Help topic.
https://sparxsystems.com/enterprise_architect_user_guide/16.0/modeling_frameworks/metamodelconstraints.html
See the Special Metaclasses section in the help page.
t-kouno
« Reply #3 on: August 10, 2022, 07:46:00 pm »
Hi all,
Thank you, Takeshi-san.
As I said, this defines them, but it doesn't describe the values returned and how they may be used in a shapescript.  Do you know?
Also, I note with my usual exasperation that although there is NOW a <profile name>::*  value, you can't investigate it with the shape script.
« Last Edit: August 10, 2022, 07:47:35 pm by Paolo F Cantoni »
« Reply #4 on: August 15, 2022, 08:42:46 am »
It's a case of our help team incorrectly extrapolating something that was added in one place and applying it to something that looks similar.
None of those are anything that shape scripts know anything about.
« Reply #5 on: August 15, 2022, 02:02:45 pm »
None of those is anything that shape scripts know anything about.
Thanks for the clarification, Eve!
As I mentioned, they didn't seem to be useful in shapescripts.
