Author Topic: v16 - Connector Label transparency  (Read 3423 times)
« on: August 09, 2022, 04:26:49 pm »
We've noticed that the middle top label transparency can vary on some diagrams.  This can only be really seen if the diagram uses background tiles.  It can vary between different stereotypes of the same type (i.e. functionally identical - as far as we can see - with only some minor rendering differences).  For the SAME stereotype, it appears to be consistent between diagrams.
We'd like to know if this is controlled by some mechanism (other than EAUI) - since we'd like our connector labels to be more consistent.
TIA,
Re: v16 - Connector Label transparency
« Reply #1 on: August 09, 2022, 07:04:40 pm »
It would simply be consistent if Sparx could make a label just appear as rendered text, not as some rectangle with text inside. Since it appears this way ever since, read Dante to find the answer...
