Author Topic: Docker setup for Sparx Systems Pro Cloud Server  (Read 43505 times)
jonpas
« on: August 13, 2022, 09:24:21 pm »
SSProCloud-Docker (GitHub) is Docker setup for Sparx Systems Pro Cloud Server for Enterprise Architect, simplifying setup and reducing maintenance on Linux systems.
This project is built on top of docker-wine, providing Wine and Winetricks for running Sparx Systems software inside a Docker container. It simplifies installation, configuration and maintenance. It also supports WebConfig in a separate connected container, reverse proxy setup with generated certificates using Traefik, x86 and x64 support and more.
We have built it for internal use and decided to open-source it in the hope others will also find it useful. Contributions are welcome, be it support for other related Sparx Systems software, more exposed configuration, or documentation.
« Last Edit: August 13, 2022, 11:31:29 pm by jonpas »
Stefan Kühnen
Re: Docker setup for Sparx Systems Pro Cloud Server
« Reply #1 on: March 27, 2023, 08:20:52 pm »
I did not investigate your solution in depth, but I can see PCS 5.1 is supported. So I assume you are still using it.
Is there a comparable solution for Prolaborate as well?
