Author Topic: Can you use !INC in a scriptlet?  (Read 40030 times)
steverumsby
« on: September 07, 2022, 06:46:03 pm »
I have some diagram scripts (Javascript) that work quite nicely and (now) quickly enough that I thought it would be useful to convert them to scriptlets (EA 16). However, when I do that I get errors on the !INC lines of my code. Is it not possible to include library files into a scriplet? If true, that makes them a whole lot less useful. Or am I doing something wrong?
Steve.
steverumsby
Re: Can you use !INC in a scriptlet?
« Reply #1 on: September 12, 2022, 07:13:21 pm »
Reply from Sparx support - no you can't, but we'll record it as a feature request for future consideration.
Just in case anybody else trips over this...
Steve.
JoNijsen
« Reply #2 on: February 06, 2024, 10:25:54 pm »
In 16.1.1628 !INC can be used in scriptlets but I found that the scriptlet is not stopped at the end of the script, which causes an error the subsequent times the scriptlet is run
« Reply #3 on: February 06, 2024, 10:34:48 pm »
what do you mean by "is not stopped at the end of the script"?
steverumsby
« Reply #4 on: February 15, 2024, 09:29:16 pm »
I've been using !INC in scriptlets since it became possible and I've never noticed this problem. What do you mean by "the scriptlet is not stopped"? What are the symptoms?
JoNijsen
« Reply #5 on: April 22, 2024, 02:59:18 am »
In the context menu of the scriplet the run option is no longer enabled.
And the second time I run it (manually or reload diagram ) it crashes EA, sometimes EA closes completely
MichPaule
« Reply #6 on: July 11, 2024, 12:08:52 am »
I can confirm that the script in the scriptlet is not stopped properly.
This is unrelated to !INC as I don't have that in my script.
After opening a diagram the script executed and the "Stop Script" context menu command remains active.
When clicked it stops the script and gets disabled (grayed).
If I click "Run Scriptlets" before stopping the script manually I'm getting an error like e.g. "redeclaration of let " which is to be expected in case of a still running script.
Looks the scriptlets feature needs some rework  :-[
MichPaule
« Reply #7 on: July 19, 2024, 03:59:51 pm »
Just FYI:
Bug report is out (#24077893)
Let's see what they have to say...
MichPaule
« Reply #8 on: September 12, 2024, 03:38:36 pm »
Just FYI:
Update:
The issue has been confirmed and will be investigated further by our development team.
JoNijsen
« Reply #9 on: December 02, 2024, 09:49:02 pm »
I mean that EA thinks the script is still running
