Author Topic: Specialize ArcGIS > Set Coordinate System  (Read 3863 times)
hainsworth
« on: September 09, 2022, 04:22:01 am »
I am using EA 16 and finding that when I click on Set Coordinate System, the application freezes and the dialog to set the coordinate system does not load.
I have also found that when a custom ArcGIS Projection is brought into EA16 through an XML import that when the data model is eventually exported the XML created by EA can't be loaded into a Geodatabase. Are custom projections supported by EA 16?
