Author Topic: Can't delete DiagramLinks, peculiar  (Read 6187 times)
Helmut Ortmann
« on: September 13, 2022, 12:32:00 am »
I tried to delete DiagramLinks and it seems not to work. The deletion of DiagramObjects work as expected.
Any idea?
Thanks and best regards,
Helmut
for (int i = dia.DiagramLinks.Count - 1; i >= 0; i = i - 1)
                        dia.DiagramLinks.DeleteAt((short)i, true);
                        countRemovedDiagramLinks++;
                    dia.DiagramLinks.Refresh();
for (int i = dia.DiagramObjects.Count - 1; i >= 0; i = i - 1)
                        dia.DiagramObjects.DeleteAt((short)i, true);
                        countRemovedDiagramObjects++;
                    //dia.Update();
                    dia.DiagramObjects.Refresh();
Helmut Ortmann
Re: Can't delete DiagramLinks, peculiar
« Reply #1 on: September 13, 2022, 12:57:03 am »
I think I have found the issue.
I have to hide the DiagramLink. Deletion doesn't work.
This is done to make it easyly possible to let reappear a Diagramlink.
« Reply #2 on: September 13, 2022, 12:59:18 am »
Yes, if you delete the diagramLink, EA simply recreates it based on the visible elements and the relations between them.
If you want to hide a relation you have to specifically tell EA that.
Back in the olden days, diagramLinks where even only recorded if you did something none default like hiding them.
