Author Topic: Reverse Engineer WMS (Oracle database) - Database builder (EA 14.1)  (Read 4342 times)
koenvanthiel
Hi I'm using the database builder in EA 14.1 to synchronize WMS (oracle database) information for reverse engineering purposes.
After installing 'Oracle in OraClient12Home1_32bit' and configuring Oracle client on my laptop, I'm able to make a connection to the database with the database builder.
I can select elements from the database to synchronize with EA.
I only face problems with synchronizing the Oracle Packages.
In EA, after changing the Stereotype in Class, i'm able to see the code in the Operation code field (body, specification). Although the actual code in the oracle database for most of the packages is long. I see that in the synchronisation process with Enterprise Architect, only the first max 32 kb on a code field is synchronized.
In EA the code field can exceed this, so this limit isn't in the EA field.
With a half synchronization this ain't usefull and also not maintainable.
Is there somebody how can point me in the right direction ?
I already tried the same thing with EA 16 trial version. I noticed that the Oracle Package 'attributes' (body, specification) didn't show up after synchronizing the oracle packages. So I wasn't able to do further investigation on that.
Kind regards.
