Author Topic: EA 16 - wrong connector appearance (aggregation) - only existing connectors  (Read 5662 times)
EAModler
when loading diagrams containing aggregation connectors, the connectors show unusual arrows.
- there are two arrows on one connectorend here at the taget side there are an arrow & a rhombus
- making new aggregation shows correct connectorend, only rhombus
Using:
- EA1605
- Oracle DB (12.2)
Changing linestyle or alignment etc. of connectors does not helps (as it did having other connector issues)
Thx upfront for any help/workaround
Arrows are about navigability.
You can change that using the Direction field in the properties of the connector.
(or by updating the navigability property of each connector end)
EAModler
Hi Geert
Thx for the fast reply.
By changing the navigability property of the connectors, the appearance can be changed as needed (navigable = an arrow and a rhombus, non-navigable & unspecific = only a rhombus).
Found also related post: https://sparxsystems.com/forums/smf/index.php/topic,47263.0.html
I think the patch mentioned by 'Takeshi K' in the above mentioned post would help fixing the issue in my models.
Link to reply with patch: https://sparxsystems.com/forums/smf/index.php/topic,47263.msg275676.html#msg275676
Best regards
EAModler
