Author Topic: MDG Diagram Type Groups  (Read 16328 times)
Re: MDG Diagram Type Groups
« Reply #15 on: November 15, 2022, 11:10:29 pm »
That worked a charm :-) Wonder why Sparx is not able to create a documentation this way (actually I don't). Alas, thanks for making this available to humans ;-)
philchudley
« Reply #16 on: November 16, 2022, 08:07:00 pm »
Many thanks WorkingMatt you beat me to it!
Not being able to use Packages to subdivide the profile into logical areas, has caught me out too. The only package I always use is for Enumerations used to type tagged values.
Not being able to use packages within <<profile>> package is a right pain especially with large MDGs, ... unless someone out there knows a way to make it work?
Phil
Models are great!
« Reply #17 on: November 16, 2022, 08:14:17 pm »
Phil
I've seen people use subpackages in profile, and apparently they didn't have any issues with it. I generally don't use subpackages because I noticed once that there was a problem with that.
This problem might have been solved for several years, but I didn't try it since.
An alternative is to use a diagram instead of a package to create your profile xml from.
That comes with it's own challenges (huge diagram, and sometimes you loose the default colors, if EA hasn't rendered the complete diagram)
« Reply #18 on: November 16, 2022, 09:19:01 pm »
I use subpackages for storing the metaclasses (and other stuff; but not for diagram proiles). However, the stereotypes must be on the <<profile>> level.
