Author Topic: Images / Attachment  (Read 6340 times)
Michel777
Images / Attachment
« on: October 07, 2022, 06:52:08 pm »
I want insert / attach a table. Of course I don't want type HTML code. Is there any way to insert / attach as image ?
Michel
Re: Images / Attachment
« Reply #1 on: October 07, 2022, 07:19:31 pm »
You can use a Boundary and make its Appearance as Alternate Image (you imported as some png/pdf ord what ever).
philchudley
« Reply #2 on: October 07, 2022, 07:52:48 pm »
You could use a linked document for an element. That allows you to create tables , place images etc on a document that is "linked" to an element.
You can also copy / paste from MS Word into the linked document.
Phil
Models are great!
BobM
« Reply #3 on: October 07, 2022, 07:56:14 pm »
If you run 16.0 you can create a diagram -> properties -> enable grid
fill the grid with your content
Use diagram frame in your original diagram
https://sparxsystems.com/enterprise_architect_user_guide/16.0/modeling_fundamentals/grid-style-diagrams.html
Michel777
« Reply #4 on: October 07, 2022, 08:32:19 pm »
Thanks for all of you. Unfortunately I forgot to say: I want insert or attach images / tables here in forum.
BobM
« Reply #5 on: October 07, 2022, 08:51:42 pm »
 ;D
Yes, you can use the [ IMG ] tags and post the image url between them (red circle)
Insert table is the blue circle
RedImage
BlueTable
Michel777
« Reply #6 on: October 07, 2022, 10:18:28 pm »
Hi Bob,
thansk a lot ! Unfortunatelly Mona Lisa is only a link (it doesn't works in all cases .. ) the  tabel is only a pure html editor (no thanks).
Obviously is there no confortable way for that.
Warm regards,
Michel
