Author Topic: BPMN Sim - How to incorporate Message Flows?  (Read 4824 times)
« on: October 19, 2022, 12:37:55 pm »
My (somewhat limited - I haven't been a serious practitioner in the past) understanding of BPMN was that you had to use Message Flows when transferring control between flow items in different Pools.  We built a non-trivial business process that followed this rule.  However, when we tried to run the simulation engine over that process, it would not get past the first Message Flow.
  • Is my understanding correct?  (You should use Message Flows and Not Sequence Flows between pools)
  • Why will the simulation work only if we convert ALL the Message Flows to Sequence Flows?
What is the best practice here?
TIA,
« Last Edit: October 31, 2022, 03:44:14 pm by Paolo F Cantoni »
Re: BPMN Sim - How to incorporate Message Flows?
« Reply #1 on: October 31, 2022, 03:44:49 pm »
Anyone? ???
Ian Mitchell
« Reply #2 on: November 01, 2022, 09:59:23 pm »
You're right Paolo - no Sequence flows between pools, only Message Flows. (I had to look back into my own BPMN course to make sure...)
www.eaDocX.com
www.theartfulmodeller.com
philchudley
« Reply #3 on: November 01, 2022, 11:57:16 pm »
Hi Paulo
Does this help?
https://sparxsystems.com/resources/user-guides/16.0/simulation/business-process-simulation-bpsim.pdf
Page 92 onwards.
It may help to work through the example listed here which uses message flow. Apparently, some kind of parameter configuration is required to get Message Flows to work. Have not tried this example myself, but it may get you nearer to a solution.
All the best
Phil
Models are great!
« Reply #4 on: November 02, 2022, 02:12:42 pm »
Hi Paolo
Does this help?
Page 92 onwards.
It may help to work through the example that uses message flow.  Apparently, some kind of parameter configuration is required to get Message Flows to work.  I have not tried this example myself, but it may get you closer to a solution.
All the best
Phil
Thanks, Phil,
yes, I have tried this exact example, but the UI no longer matches the instructions from page 93.  Also, it's unclear to me why we need to use BPSim instead of the more straightforward BPMN simulation when we use messages unless you can't handle parallel execution in simple BPMN simulation.  So we must use the more powerful BPSim in those circumstances.  That seems reasonable, but I haven't encountered it in any discussion.  Thoughts?
I would really like some Sparxians; after all, they wrote the stuff to explain more the why and how this works.
« Reply #5 on: November 02, 2022, 02:16:56 pm »
You're right, Paolo - no Sequence flows between pools, only Message Flows.  (I had to look back into my own BPMN course to make sure...)
Hi Ian,
Interestingly, if I break the rule (which I have to to get my BPMN Sim scenario simulations working), validating the package DOESN'T show any errors (for the Sequence Flows crossing Pool boundaries).  I do disable strict connector syntax, but I would have thought that would not invalidate the validation process (pun intended!).
