Author Topic: RTF Generation - Package Filter  (Read 4525 times)
Andreas1975
« on: May 27, 2013, 06:48:26 pm »
Hi all.
Is there an easy way of filtering Packages (based on package stereotype) when generating a RTF Doc?
In the generation dialogue, it seems like possible to filter on all other types of objects.
The option to include/exclude on the Package itself is not possible, since other reports might need that Package
regards
Andreas
Stefan Bolleininger
Re: RTF Generation - Package Filter
« Reply #1 on: May 27, 2013, 07:30:42 pm »
The package can be addressed using the filters from "Search on: Elements"
it sounds a bit weird, but package is dopped within elements  :) :)
Best regards
Stefan
Andreas1975
« Reply #2 on: May 27, 2013, 09:00:43 pm »
Yes, I thought so too for a moment, so I tried it out.
Element Filter, filtered on stereotype, but still it picks up all packages, regardless of package stereotype.
(Tried both as generation options, as well as on the properties on the RTF itself).
Not sure if it's a bug, or if I'm doing something wrong. Someone can confirm this to work?
thanks.
regards
Andreas
Stefan Bolleininger
« Reply #3 on: May 27, 2013, 09:07:18 pm »
Did you check the checkboc "required"
and
did you implement the filter vice versa? "Only elements are included which..."
So it sould be
elements where Stereotype NOT EQUAL to "your-stereotype"
  • required.
in my cases it works quite fine
Regards
Stefan
