Author Topic: v16 - BPMN Simulation, can we get access to the Simulation window contents?  (Read 3724 times)
Now that we are running scenario simulations for our Process under Simulation, we are manually placing the results of the Simulation (the trace of the Simulation) in an artifact on the scenario diagram.  The intent is that if we change the Process under Simulation, we can re-run the Process under Simulation against the same scenario and compare and contrast the results.
However, this is a manual process.  Is there any way to get access to the simulation window under automation?
TIA,
