Author Topic: Automated HTML Report - DocumentGenerator too granular  (Read 3667 times)
esscasey
« on: November 02, 2022, 01:59:14 am »
I'm trying to automate the generation of an HTML report for an EA model using the C# API from EA version 16.0. What I want to do is generate model documentation automatically every night so that the docs are in sync with the current model.
I've been able to generate HTML output package-by-package using the DocumentGenerator class, but I have a couple problems/questions. First, here is the relevant code that generates the HTML:
        documentGenerator.DocumentPackage(modelPackage.PackageID, 0, "Model Report");
        for (short subID = 0; subID < modelPackage.Packages.Count; subID++)
            Package subPackage = (Package) modelPackage.Packages.GetAt(subID);
            if (!documentGenerator.DocumentPackage(subPackage.PackageID, 1, "Model Report"))
                    Console.WriteLine("last document error: " + documentGenerator.GetLastError());
        documentGenerator.SaveDocument("C:\\development\\NewEms\\ModelAutomation\\output.html", DocumentType.dtHTML);
Questions:
1. Is the for loop really necessary? Is there another method that I can call that will generate the HTML document for the entire package, similar to using Publish -> Model Reports -> HTML -> Standard HTML Report from within Enterprise Architect? I could write a recursive subpackage traversal method but I'd like to avoid that if possible.
2. The automated HTML doesn't look exactly like the HTML generated from EA. Cosmetic differences aside; a) the hyperlinks in the model diagrams aren't clickable to allow navigation from diagram-to-diagram; b) there's no browser-like frame to allow easy navigation within the HTML document.
Is there a better/simpler way to accomplish my goal?
Thanks in advance,
Casey
Re: Automated HTML Report - DocumentGenerator too granular
« Reply #1 on: November 02, 2022, 09:32:17 am »
Hi Casey,
We use ProjectInterface.RunHTMLReport(...) to export the branch.
Example:
      ProcessHTMLBranch = oProjectInterface.RunHTMLReport(HTMLBranchUUID, exportPath, ".png","<default>", ".htm")
To ensure a specific "top" diagram, we open that, just before generating.
esscasey
« Reply #2 on: November 03, 2022, 07:41:42 am »
Thank you Paulo! That was exactly what I was looking for.
wivel
  • Driven by Models
« Reply #3 on: November 03, 2022, 08:22:38 am »
It would be nice it the RunHTMLReport function could take the GUID/ObjectID of the diagram you would like to have as default, as parameter.
Henrik
