Author Topic: Message to self in UML Class diagram  (Read 15665 times)
flitjens
« on: November 02, 2022, 11:57:43 pm »
Hello all,
I would like to know if it is possible to show dependencies to self in a class diagram as an association instead of a member variable when the class diagram is generated by importing code.
For example:
I have a LinkedList pointing to the root of type ListItem. ListItem has to references to itself, _next and _previous.
The dependency from LinkedList to ListItem is presented as an association with label _root, but _next and _previous of ListItem is only showed as private member. For clarity I would like to present them as an association.
Is that possible?
Kind regards,
Frank Litjens
Re: Message to self in UML Class diagram
« Reply #1 on: November 03, 2022, 12:07:10 am »
Unfortunately, there little you can do with regards to reverse engineering code.
flitjens
« Reply #2 on: November 03, 2022, 12:39:18 am »
Hi Geert,
Thanks for your quick response. Is it possible than to add that association in the model without affecting the underlying code?
Kind regards,
Frank Litjens
« Reply #3 on: November 03, 2022, 12:49:17 am »
For forward engineering, you can change the templates, so you should be able to do so without affecting the code.
But I'm not sure if this is a route you want to be traveling on.
I try to stay as far away as possible from the code generation templates.
jfzouain
« Reply #4 on: November 09, 2022, 03:34:14 am »
Hi Frank
I will stay away from changing the template as Geert says, but if I understood you correctly you can show dependency to self in a class, add it to the Operation Return Type = > Self
Regards
Jose
Best regards
Jose Zouain
jfzouain
« Reply #5 on: November 09, 2022, 03:42:29 am »
Operation:
Parameters: object, ushort
Return type: Self
 -> Go to the code and include the code there
It will generate the code correctly
Sorry had issues pasting the class diagram, so included only 1 operation
Best regards
Jose Zouain
