Author Topic: Document generation broken in v16.1  (Read 273064 times)
Re: Document generation broken in v16.1
« Reply #30 on: August 01, 2024, 05:36:34 pm »
Well I use this as well and it is set to A4. The strange thing is I get A4 but used as letter. I only create PDF. Maybe I try RTF and Word to figure out if this is a PDF issue.
We always generate to Word first, and then save as PDF where needed.
Often we do change some minor details left and right (diagram sizes, table of contents, some page breaks here and there) before saving the document.
PeterHeintz
« Reply #31 on: August 01, 2024, 07:38:53 pm »
Geert this what I try to avoid since years with success.
My target is: generate, deliver, ready without any fiddeling around.
Best regards,
Peter Heintz
Modesto Vega
« Reply #32 on: August 02, 2024, 03:18:45 am »
Have used a similar approach to Geert for a number of years, generate rtf or word, save locally, if rtf convert to word, modify local copy, and, nowadays upload to SharePoint. I gave up generating PDFs long time ago.
Typical changes that in my experience need to be done after converting to word:
1) grammar and spelling, Sparx EA grammar and spelling features are far behind what Word can do.
2) format adjustments, such as maximising page usage and, at the same time, reducing document size, or fixing tables; Sparx never seems to get table formatting right to a publishable standard, specifically header row shading.
3) acknowledging contributors and adding document history.
4) writing executive summaries.
Improvements I would love, conditional formatting, specifically easily and dynamically change the page size and orientation based on a diagram’s page settings.
PeterHeintz
« Reply #33 on: August 02, 2024, 04:20:24 pm »
Thank you Modesto Vega!
Exept your point one I managed all with my templates used directly to greate PDF and I intend to stay this way.
My final goal is to deliver in middterm future just the model to outr assessores and I whant to say “Hey if you need a document for whatever reason just go to the package and generate it yourself".
And currenly with PDF I am closer to what I need (less problems). All in common is that in V1701 digrams look odd. What is in PDF worse is that neither uses the horinzontal nor the vertical page space is used right.
Best regards,
Peter Heintz
PeterHeintz
« Reply #34 on: August 02, 2024, 09:35:09 pm »
A am still trying to find out what my PDF small page usage proble is. No I realized that I get an error when trining to open the PDF with Acrobart Reader I get an error message like:
The root object is missed or invalid.
Any idea on that?
Best regards,
Peter Heintz
« Reply #35 on: August 02, 2024, 10:02:10 pm »
Any idea on that?
I just tried it myself on v17 and got the same error message when Adobe tried to open the PDF.
The file did open in Chrome, but I did saw the same small page problem you mentioned.
The document generated perfectly (in A4) when using .docx
Looks like the PDF generator used by EA is broken.
Did you report this as a bug?
PeterHeintz
« Reply #36 on: August 02, 2024, 10:31:39 pm »
I belief for V16 long time ago, but not for V17. Thank you! So it is for sure not a problem of my PC.
Best regards,
Peter Heintz
PeterHeintz
« Reply #37 on: September 09, 2024, 06:59:43 pm »
Today I tested the PDF generation with build 1702.
Now the PDF report can also be opend with Acrobat Reader.
However still the usage of my A4 page seem to be  "letter" or something else.
In other word only round about 75% of the page size is used for content.
Any ida on this?
Best regards,
Peter Heintz
PeterHeintz
« Reply #38 on: November 15, 2024, 01:53:30 am »
From my perspective the heading issue is now solved within the builds 1704 and 1629.
However the problem that PDF reports do only use ~75% of the page size still exist in both builds above.
And with V17 there is an additional issue with IBD diagrams with in V17 loos very odd.
I will rise a bug report!
Best regards,
Peter Heintz
« Reply #39 on: November 15, 2024, 02:01:37 am »
Good to see there is progress. Keep pushing for the other open issues.
chrislro
Re: Document generation broken in v16.1, also 17!?
« Reply #40 on: November 30, 2024, 02:52:06 am »
I generated with EA17.0.1704 (64bit) a document to test it. Database content, template, styles and document generation settings are unchanged. Document is stored as a resource, output is Word format. The EA17 generated document fails with chapter order (order is mixed up), has duplicate content (some chapters are just present twice at different locations),  and some diagrams are messed up, too: Elements unexpectedly have a different size than shown in EA itself, arrows and connections are missing. Some diagrams are perfect.
As I don't want to review hundreds of pages of all generated documents, I will still stick with EA15.2.1650 for document generation. Maybe EA18 will fix it. But I start losing the hope  :'(
Jens Nötzold
« Reply #41 on: January 27, 2025, 09:23:54 pm »
After fiddling around with templates for many (>20) years, almost dealing with workarounds for unexpected rendering results.
I recently gave up moving towards v16.1, again.
Besides being restricted to letter size pages, Sparx's EA is not able to render German characters, at least on fields like {ElemTest.Notes} or {PackageGlossaryMeaning} and, perhaps others. I see them rendered escaped (ä) or escorted by curious switching of font styles and -sizes. Maybe the root cause of other effects as well.
And now again, no surprise, with v17.0.1704 Sparxs introduces new varieties: Header and Footer are not rendered any more, unless a cover page is defined.
To make it clear: Linear RTF/PDF documents are still the most important interface between me and my customers and will be. THEY ARE NOT A NICE TO HAVE!
So: Should I stay with Sparx/EA? 6 license renewals later we're still stuck with Version 15.2 and 32-Bit.
Gruß
Jens
« Reply #42 on: January 27, 2025, 10:22:27 pm »
Hi Jens,
Make sure to contact sparx support with your issues (if you haven't already)
They eventually fixed all the issues I reported and we are now preparing for an upgrade to v17
chrislro
« Reply #43 on: January 28, 2025, 12:15:02 am »
I still like EA as a tool. I use v17 for editing, but I will still stick with EA15.2.1650 for document generation. You can install both on the same PC: EA15.2 is x86, then install EA17 as 64 bit, so they do not share the same Program Files ... works for me (still a workaround!) [as long as you are not relying on x86 plugins]
chrislro
« Reply #44 on: July 23, 2025, 01:11:33 am »
Just wanted to post my experience with 17.1:
I started some time ago creating new content in EA 17.0, today I am using the latest available 17.1 (x64). I have no issues with document generation for the newly created content. I try to ensure that the Model is not too complicated (e.g. no elements below elements, just one level with diagrams or embedded elements), and I do not include children when parent is filtered (this caused issues in false chapter generation).
I am not sure whether document generation with old content I created the last years also works with 17.1, but for that I have the fallback of using EA 15.2 just for exporting.
