Author Topic: V16 - BPSim "Could not find Java Runtime Environment"  (Read 6426 times)
« on: November 07, 2022, 02:19:43 pm »
On three of our machines, BPSim has suddenly stopped working the "Configure BPSim" Window says: "Could not find Java Runtime Environment".  We've tried uninstalling and re-installing EA but to no avail!  Does anyone know what's going on?  As far as we know (typical user response), we didn't do anything.  It was working last week.
TIA,
wivel
  • Driven by Models
Re: V16 - BPSim "Could not find Java Runtime Environment"
« Reply #1 on: November 08, 2022, 01:43:20 am »
Hi Paolo
Have you has any updates done on your machines? Could be that the an update have removed the JRE from your machines, since it is not only one machine that fails.
Try to open a terminal window and write 'java -version'. If it fails, the JRE is either removed or not in the PATH.
Henrik
« Reply #2 on: November 08, 2022, 01:00:15 pm »
Hi Paolo
Have you had any updates done on your machines? Could be that an update has removed the JRE from your machines since it is not only one machine that fails.
Henrik
Hi Henrik,
Overnight, the JRE Appears to have returned on some machines!  Although on those, only for the 32-bit version.  The 64-bit version still fails!
On the working machines, "java -version" returns:
java version "15.0.1" 2020-10-20
Java(TM) SE Runtime Environment (build 15.0.1+9-18)
Java HotSpot(TM) 64-Bit Server VM (build 15.0.1+9-18, mixed mode, sharing)
and the JRE is to be found in C:\Program Files\Common Files\Oracle\Java\javapath as mentioned in the "path" environment variable.
On the non-working machines, it's nowhere to be found!
Repairing EA (both 64-bit and 32-bit) doesn't add the JRE.  So the question is is it a Sparx EA installation or an infrastructure problem?  The 32-bit OK and 64-bit broken issue would point to the Sparx installation.  But the JRE missing altogether might suggest otherwise.
Does anyone know if the EA installation also adds the JRE if missing?
Flummoxed!
« Last Edit: November 08, 2022, 01:02:19 pm by Paolo F Cantoni »
« Reply #3 on: November 08, 2022, 02:18:50 pm »
No. EA does not include any copy of Java in its installer.
« Reply #4 on: November 08, 2022, 10:13:19 pm »
Thanks, Eve,
For confirming.  I didn't think so from the behaviour.
Do you know where EA 64-bit is looking for the JRE?
For those machines without the JRE, We'll have to install it, I guess.
« Reply #5 on: November 09, 2022, 08:17:19 am »
It's looking using a registry key that I believe the JRE creates in its installation.
« Reply #6 on: November 09, 2022, 12:46:59 pm »
It's looking to use a registry key that I believe the JRE creates in its installation.
So it's NOT looking for the same key as 32-bit?  Are you able to identify the key?
« Reply #7 on: November 09, 2022, 11:45:47 pm »
I installed the latest JRE on all the machines, and both 32-bit and 64-bit now see the JRE.
java version "1.8.0_351"
Java(TM) SE Runtime Environment (build 1.8.0_351-b10)
Java HotSpot(TM) 64-Bit Server VM (build 25.351-b10, mixed mode)
