Author Topic: MDG is generated with wrong encoding  (Read 21360 times)
Giu Platania
  • As Above so Below
    • Linkedin
« on: November 09, 2022, 01:04:38 am »
I have several MDGs that are generated with ANSI encoding
<?xml version="1.0" encoding="windows-1252"?>
this appears to be independent from the database version I use.
e.g.
MDG 1
Connection / DBMS:  Local EAP File
Database Schema Version: 1558
Database Version: 4.01
Version Date: Jan-31-2004
MDG 2
Database Schema Version: pre-1558
the result is the same:
the UMl profile and the MDG XML are generated with windows-1252
EA version is 15.02.1560 Unicode and Windows 10 is set to use UTF-8 by default.
what else could be?  :o
Giuseppe Platania
Enterprise Architect
Door Business Consulting
"As above so below, to accomplish the miracles of the One Thing" - Trismegistus
The above content reflects my own opinion and is not endorsed by Monthy Python
The above is NOT a reference to Monty Python
Re: MDG is generated with wrong encoding
« Reply #1 on: November 09, 2022, 01:25:38 am »
Have you checked the option
Start | Desktop | Preferences | XML Specifications | Code Page
Giu Platania
  • As Above so Below
    • Linkedin
« Reply #2 on: November 09, 2022, 02:13:34 am »
It works!
thank you Geert
Giuseppe Platania
