Author Topic: Unable to disable eaworker  (Read 41391 times)
nilspc
« on: November 10, 2022, 09:14:19 pm »
I tested using "Periodically generate diagram images for WebEA & Prolaborate", but since we are using an MDG and the worker does not we cannot use it.
My problem now is that I cannot disable the worker.
I've obviously disabled it in the "Configure database manager" and even deleted the connection and created a new one with the same name.
any ideas ?
/Nils
wivel
  • Driven by Models
Re: Unable to disable eaworker
« Reply #1 on: November 11, 2022, 03:55:38 am »
Hi Nils
You have to go to the server where PCS and EAWorker is install and kill all EAWorker.exe instances using the task manager. Or restart the server.
It’s a known issue that the EAWorker, for some reason, runs in several instances, and disabling it will only stop one instance. Not all of them.
You can also install a copy of EA on the PCS server and install the MDG there. Then the EAWorker can work with it.
Henrik
nilspc
« Reply #2 on: November 11, 2022, 08:24:35 pm »
Thank Henrik,
That solved the problem
/Nils  ;D
wivel
  • Driven by Models
« Reply #3 on: November 11, 2022, 10:40:04 pm »
Hi Nils
Glad to hear. Did you also try installing EA on the PCS server and install the MDG there?
Henrik
nilspc
« Reply #4 on: November 16, 2022, 12:12:04 am »
Hi Henrik,
No, not relevant anymore. It's enough to create the diagrams when we change then i EA
/Nils
wivel
  • Driven by Models
« Reply #5 on: November 16, 2022, 01:08:18 am »
Hi Henrik,
/Nils
Thanks for the update. EAWorker has some quirks that can be really annoying, or perhaps features you need to be aware of before going that route.
You can read more about it in tis thread: https://sparxsystems.com/forums/smf/index.php/topic,46789.0.html
Henrik
