Author Topic: Where has Extension gone?  (Read 12524 times)
Modesto Vega
« on: November 15, 2022, 01:25:14 am »
In Sparx EA v15 we used an Extension connector to link and stereotype to a metaclass. We are trying to modify an MDG created using v15 with v16 and the Extension connector is not available in the context model that appears when trying to draw a relationship by dragging the connector icon between to elements. However, it is available in the toolbox but all attempts to use it result on non-UML compliant error message.
Has anything changed?
Re: Where has Extension gone?
« Reply #1 on: November 15, 2022, 02:15:34 am »
I'm afraid you'll have to turn off strict connector syntax, and use the toolbox to create the Extension relation.
And of course report it as a bug.
Modesto Vega
« Reply #2 on: November 15, 2022, 03:38:14 am »
Thanks Geert, v16.1 was released today before submitting a bug I probably should the I can reproduce the issue with v16.1, we are using v16.0 (build 1605).
« Reply #3 on: November 15, 2022, 03:48:50 am »
You can submit the bug for 16.0. It's up to Sparx to see if this is still an issue in the latest version;
We (the users) do enough QA as it is.
Modesto Vega
« Reply #4 on: November 15, 2022, 03:56:06 am »
Thank you, Geert; bug reported.
Modesto Vega
« Reply #5 on: November 15, 2022, 08:18:32 pm »
Reported as a bug and got a reply in less than 24 hours. To paraphrase the reply: it is not a bug, we cannot reproduce it.
Yet, I have no trouble reproducing it with 16.0.1605 64-bit and was not given an indication of whether it was fixed with v16.1 released yesterday.
[SNIP]
We do, and sometimes Sparx support appears to be tasked with batting all balls out of bounds.
« Reply #6 on: November 15, 2022, 08:57:55 pm »
I can reproduce the issue, on the latest 16.1.1621
The quicklinker gives me
- Substitution
- metaconstraint
- metarelationship
- stereotyped relationship
But no Extension.
I'll report a bug as well.
Modesto Vega
« Reply #7 on: November 15, 2022, 09:21:00 pm »
- Substitution
- metaconstraint
- metarelationship
But no Extension.
Thanks Geert, really much appreciated. This is exactly the same behaviour I am seeing in v16.0 (build 1605).
« Reply #8 on: November 15, 2022, 09:25:39 pm »
I wonder what those Sparxians are doing the whole day. Probably feasting upon the license payed by customers in the futile hope to get a better product.
« Last Edit: November 15, 2022, 10:56:23 pm by qwerty »
philchudley
« Reply #9 on: November 15, 2022, 10:34:59 pm »
Bizarrely the following does work in EA v 16.1
Add a Stereotype onto a diagram
Drag the quicklink to an empty space on the diagram and select Metaclass
Extension appears as the first entry in the Quicklink menu
Choose the metaclass and presto all works fine
Go figure
Phil
Models are great!
« Reply #10 on: November 15, 2022, 11:21:00 pm »
Even weirder:
If I create a brand new .qea model and add a metaclass and a stereotype on a diagram, I get the extension relation in the quicklinker.
Digging a bit further I found that the difference is the fact that existing metaclasses have stereotype metaclass, whereas the new metaclasses have stereotype UML Standard Profile::metaclass
So it's only an issue for existing metaclasses, not for new metaclasses.
PS. Damn, I did it again, I should really let Sparx do their own QA and support. ;D
« Reply #11 on: November 16, 2022, 12:01:13 am »
Even weirder:
Digging a bit further, I found that the difference is the fact that existing metaclasses have stereotype metaclass, whereas the new metaclasses have stereotype UML Standard Profile::metaclass
PS. Damn, I did it again. I should really let Sparx do their own QA and support. ;D
I know the feeling!
However, you needed to get to the bottom of things.  Until you understood why you weren't sure how far the "rot" went.
We've found similar issues.
Thanks for tracking this one down.
Modesto Vega
« Reply #12 on: November 16, 2022, 12:29:46 am »
Geert and Phil thank you for tracking this down.
In conclusion, it is only a bug if you are updating a profile or MDG put together with a previous version of Sparx EA. If you are starting from scratch with each version is not a bug. Only a sparxian will think that way.
Has Sparx Systems decided to change something so fundamental without providing an upgrade mechanism and making an effort to bringing to the attention of their customers?
« Reply #13 on: November 16, 2022, 01:06:00 am »
Yeah, par for the course I'm afraid. :-\
"upgrading" is not really difficult though. A 20 line script should suffice to set the fully qualified stereotype. Even an XMI export/import could be enough to solve the problem.
(make sure you don't have a metaclass stereotype in the model stereotype list)
Modesto Vega
« Reply #14 on: November 16, 2022, 01:13:42 am »
I presume that script that loops through all elements in package will do the "upgrade" job. Not too please about having to find the time for such "upgrade".
