Author Topic: Where has Extension gone?  (Read 12412 times)
Re: Where has Extension gone?
« Reply #15 on: November 16, 2022, 01:15:49 am »
Yeah, but I would try the xmi export/import route first. That won't take more than 5 minutes
Modesto Vega
« Reply #16 on: November 16, 2022, 01:48:36 am »
My primary concern right now is backward compatibility. Not everybody is running v16 and don't want to run the risk of updating the MDG with v16 just to find out that it does not work in v15.
Curiously v15 (Build 1560) does recognise UML Standard Profile::metaclass as valid, as well as just metaclass.
« Reply #17 on: November 16, 2022, 01:54:32 am »
I'm would expect both stereotypes to work in both versions.
The only annoying thing in v16 is the missing quicklink (and the error is you haven't disabled strict connector syntax).
But when you use the option "Edit with Profile" helper, you don't need to create those extension relations manually.
« Reply #18 on: November 26, 2022, 12:48:02 am »
According to the release notes this should have been fixed in version 1622:https://sparxsystems.com/products/ea/history.html#1622
