Author Topic: Import .NET6.0 SDK solution does not import classes  (Read 4815 times)
flitjens
« on: November 16, 2022, 01:51:02 am »
When I try to import a normal visual studio solution having a .NET6.0 console application it does not generate any class.
I'm using EA 16.1 but previous versions had the same problem.
Do I miss something?
Kind regards,
Frank Litjens
Eiberle
Re: Import .NET6.0 SDK solution does not import classes
« Reply #1 on: November 28, 2022, 03:59:10 am »
I have the same problem. It looks like, that microsoft has changed the strategy of source code file discovery and the project file does no longer contain the references to the source code files. My guess is, that EA has not been updated to respond to this new behavior and therefore simply does not import the files in the folder (and sub-folders).
Mybe this will  hopefully fixed someday.
Greetings,
Thomas
flitjens
« Reply #2 on: January 02, 2023, 11:48:42 pm »
Hi Thomas,
I received feedback from Sparx and they reported the issue as a known issue. It is registered and will probably be handled in the futute.
Greetings,
Frank Litjens
