Author Topic: Duplicated tags when I use import package from csv  (Read 4986 times)
fabbri67
« on: November 22, 2022, 04:27:41 am »
Hello all,
I have EA version 16 .
When I update requirements, into a package, by importing a csv file,
I have a big issue:
after importing the csv file I have duplicated tags with the same name in every requirement!
Imagine, for example, that I have a tag called "test_tag" with the value "value1";
and imagine that, in csv file, there is a requirement (with a certain GUID already present in EA project)
that has the tag "test_tag" with the value "value2".
After importing the csv file, I have (in the EA project, for that requirement) 2 tags with the same name!
A tag "test_tag" with the value "value1" and another tag "test_tag" with value "value2"
(so I have the tag duplicated!).
It's an annoying problem that wastes a lot of time:
imagine having to change the value of a tag to 1000 requirements!
In this case I have to do 1000 manual operations to delete the duplicate tag.
How can I do, when importing the csv, to avoid the duplicate tag?
If anyone has a solution it would save me a ton of time.
Re: Duplicated tags when I use import package from csv
« Reply #1 on: November 22, 2022, 04:34:58 am »
I would start by reporting a bug to Sparx, and seeing what they have to say about it.
If needed go back to version 15.2
Takeshi K
    • Sparx Systems Japan
« Reply #2 on: November 22, 2022, 10:26:12 am »
Hello fabbri67,
The issue has been fixed on the version 16.1 build 1621. Please try with the latest build.
t-kouno
