Author Topic: Project.ProjectTransfer does not support transfer to .qea file  (Read 12872 times)
« on: November 30, 2022, 10:21:39 pm »
In v16.1 the new default file format is .qea.
Unfortunately, when using the API to automate project transfer, it doesn't work if you specify a .qea target file.
It works fine when specifying a .eapx target file.
Steps to Reproduce:
Execute code
dim transferCompleted
transferCompleted = projectInterface.ProjectTransfer(eapString, "C:\temp\export.qea", logfilePath)
with a valid connectionstrign in eapString, and a valid path to the logfile in logfilePath
Reported
« Last Edit: December 02, 2022, 04:05:51 am by Geert Bellekens »
Sunshine
  • Its the results that count
Re: Project.ProjectTransfer does not support transfer to .qea file
« Reply #1 on: December 01, 2022, 07:36:05 pm »
In the words of John McEnroe the American tennis player.
"You cannot be serious"
Happy to help
« Reply #2 on: December 05, 2022, 07:03:49 pm »
Received confirmation from Sparx that this is indeed not supported.
They have logged a feature request on my behalf.
« Reply #3 on: May 02, 2023, 03:08:05 pm »
As of April 2023, v16.1.1625, we have been able to transfer to .qea files from our main SQL Server Repository using Project.ProjectTransfer (the file names are variables - not literals).
However, the transfers are very slow!  Whereas before using .eapx files as the target, the transfers took 15-20 mins (for a nearly 2GB .eapx file), it now takes 2 hours (for a 2.25Gb .qea target file)!
Is this to be expected?  Is there any known reason why it takes so much longer?
TIA,
Sunshine
« Reply #4 on: May 02, 2023, 05:18:50 pm »
Interesting we have a SQL Server central repository and when I do a project transfer to qea file it takes around 15 min for 1.7GB.
Happy to help
« Reply #5 on: May 02, 2023, 07:46:08 pm »
Interesting we have a SQL Server central repository, and when I do a project transfer to the qea file it takes around 15 min for 1.7GB.
Hi Sunshine,
Is that an API call or a manual transfer?  I might try a manual transfer and see if I get a different result.
[Edit: It made no difference - manual transfer also 2 hours]
« Last Edit: May 02, 2023, 10:33:55 pm by Paolo F Cantoni »
Sunshine
« Reply #6 on: May 05, 2023, 05:31:31 pm »
I kick it off via the user interface
Happy to help
