Author Topic: MDA transformation explodes in memory usage  (Read 5568 times)
Thomas Arnbjerg
« on: December 09, 2022, 12:21:52 am »
Hi all,
We have an MDA transformation, which has suddenly caused EA to use extreme amounts of memory (>30 GB) and the transformation never completes. I have narrowed the problem down to 1 custom template (Class__xx). I've removed all calls to other templates (e.g. Connector__xx) with the list macro, but the problem persists.
Any suggestions?
The template is shown below:
%if elemType != "Component"%
%endTemplate%
%if classLanguage == "Java"%
Package
   %TRANSFORM_REFERENCE("MessagingClassesPackage","IMPLEMENTATION", "ONLY_ONE")%
   name = "datastructureclasses"
   Class
      %TRANSFORM_REFERENCE("ComponentEventbusFacade",className,classGUID)%
      name=%qt%%className%Implementation%qt%
      notes=%qt%*** AUTOGENERATED - Do not modify by hand. ***
   This class implements the interface against the system for component '%className%'.%qt%
      Language="Java"
      stereotype="system_interface_implementation"
      Tag
         name="application"
         value=%qt%%className%%qt%
      Attribute
         name="PROPERTYBAGNAME"
         default=%qt%%sl%%qt%propertyBagName%sl%%qt%%qt%
         type="String"
         Constant="true"
      Attribute
         name="COMMANDID"
         default=%qt%%sl%%qt%commandId%sl%%qt%%qt%
         type="String"
         Constant="true"
      Attribute
         Name = "communicationMap"
         Type="Map<String, ISocketChannel>"
      Attribute
         Name = "logger"
         Type="Logger"
      Operation
         Name = "handleMessage"
         Type="void"
         Scope="public"
         Parameter
            Name="_message"
            Type="IMessage"
         Code=%qt%
try
   PropertyBagMessage pbMessage = (PropertyBagMessage)_message;
   Map<String, Object> propertyBag = pbMessage.getPropertyMap();
   return;
catch(Exception e)
   logger.error(String.format(%sl%%qt%Exception caught: %s  Stack trace:%s%sl%%qt%, e.getMessage(), e.getStackTrace()));
   throw e;
               %qt%
      Header=%qt%
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
import dk.medtrace.util.socket.data.PropertyBagMessage;
import dk.medtrace.util.socket.interfaces.ISocketChannel;
import dk.medtrace.util.socket.impl.SocketFactoryImpl;
import dk.medtrace.util.socket.interfaces.IMessage;
import dk.medtrace.util.autogenerated.framework.ESocketChannel;
import dk.medtrace.util.autogenerated.framework.ComponentSocketChannels;
import java.util.*;
%qt%
   Realisation
      %TRANSFORM_REFERENCE("FacadeRealizesInterface",className,classGUID)%
      direction="Source->Destination"
      Source
      Target
         %TRANSFORM_REFERENCE("ComponentInterfaceClass",className,classGUID)%
   Realisation
      %TRANSFORM_REFERENCE("FacadeRealizesIMessageHandler",className,classGUID)%
      Source
      Target
         GUID="{115E54AE-749C-4552-92D2-C8BDF85BD460}"
%endIf%
Re: MDA transformation explodes in memory usage
« Reply #1 on: December 09, 2022, 12:36:06 am »
Thomas,
Are you sure you didn't create an endless loop somewhere?
e.g.
- templateA calls template B
- templateB calls templateC
- templateC calls templateA
That seems like a (the only?) logical explanation for that behavior.
I'm not very familiar with the template language (and I try to stay as far away from it as possible), so I can't quickly identify if that is the case here.
Thomas Arnbjerg
« Reply #2 on: December 09, 2022, 12:39:55 am »
Thanks for the response.
I found the reason
'%' needs to be escaped with '%pc%' in 'logger.error(String.format(%sl%%qt%Exception caught: %s  Stack trace:%s%sl%%qt%, e.getMessage(), e.getStackTrace()));'
« Reply #3 on: December 09, 2022, 01:03:17 am »
You see why I try to stay away from it  ;D
Thomas Arnbjerg
« Reply #4 on: December 09, 2022, 01:06:10 am »
Yeah - it's one of those situations where the entry barrier is quite high - but so are the gains.
This is one of the most powerful features with model driven development. Hope Sparx will improve ease-of-use - lot's of low hanging fruits.
« Reply #5 on: December 09, 2022, 02:11:54 am »
I'm not convinced.
If you are familiar with scripting and EA's API, it's usually faster, and definitely more flexible to create your own transformation script.
With the added bonus that you can actually debug when things don't work as planned.
« Reply #6 on: December 09, 2022, 02:14:38 am »
They may hang low, those fruits. But they are not tasty. I'd wish they would not waste time here but improve the API.
« Reply #7 on: December 09, 2022, 09:20:11 am »
"you might well think that; I couldn't possibly say that!"
