Author Topic: EA 16 build 160X and DOORS add-in 3.0.3xxx  (Read 4307 times)
MarcinG
« on: January 05, 2023, 02:25:24 am »
anyone installed/enabled DOORS add-in successfully ?  It is not appearing in Add-in window, and it seems that it gets installed on the path used by 32 bit software (C:\Program Files (x86)), while EA 16 gets installed into the other location (C:\Program Files).
Any help would be appreciated.
Best regards
Marcin
Re: EA 16 build 160X and DOORS add-in 3.0.3xxx
« Reply #1 on: January 09, 2023, 04:27:58 pm »
did anyone install/enabled the DOORS add-in successfully?  It does not appear in the Add-in window, and it seems that it gets installed on the path used by 32-bit software (C:\Program Files (x86)), while EA 16 gets installed into the other location (C:\Program Files).
Best regards
Marcin
Hi Marcin,
If you are using the 64-bit EA (which you seem to be from the path), then the 32-bit Add-In won't be visible.  I have the same problem with my own Add-In, which is still only 32-bit.
Try installing the 32-bit v16 EA, and it should then appear.
