Author Topic: various releases - 16.1 + 15.0 with dbms scheme - 1558 ?  (Read 3735 times)
martas
« on: January 07, 2023, 02:02:38 am »
we have recently used version 15.0 , now we have upgraded 3 pcs to 16.1 (but most  - about 30 stays at 15.0).
But when I choose help-about, I see the latest dbms schema, which seems to me weird .
It says:
Connection /DBMS:OLEDB -MS SQL Server
Database Schema Version:1558
Any knowledge about this ?
Can there be any issues ?
Re: various releases - 16.1 + 15.0 with dbms scheme - 1558 ?
« Reply #1 on: January 07, 2023, 04:13:34 am »
The database is at the schema it is. That is not related to the version of the EA client.
martas
« Reply #2 on: January 09, 2023, 07:34:19 pm »
So isn't there absolutely no impact of the database schema to the functionality of the client ?
And not problems if the schema is at version which came later than the client ?
« Reply #3 on: January 09, 2023, 07:54:56 pm »
In most cases that is not a problem. Sometimes they publish an update to the schema that is not backwards compatible, but that ususally gets a warning.
They recently did that for the t_images table. If you apply that update you can't use the model with versions before 15.
