Author Topic: can't unlock diagram  (Read 64262 times)
George..Brennan
« on: January 13, 2023, 11:19:36 pm »
Hi all,
I have a diagram recently created and now I can't move/edit position info...
The diagram has a grey check against the locked menu which I can't change.
It has a green border when clicked - presentation mode is off and all other EA apps are offline.
There is no lock in t_diagram.
I've raised a support call
Any advice?
Other than copy &  recreate the diagram.
16.1.1622 32bit
George
Re: can't unlock diagram
« Reply #1 on: January 14, 2023, 02:38:53 am »
Maybe you're in presentation mode?
George..Brennan
« Reply #2 on: January 14, 2023, 03:35:00 am »
Takeshi K
    • Sparx Systems Japan
« Reply #3 on: January 16, 2023, 10:19:40 am »
Hello George,
When a diagram is locked and the menu item to unlock is disabled, there are following cases (I think):
- locked by the Version Control
- locked by the Security
- locked by the API method Package.SetReadOnly()
- a file is read-only (in some file type)
- opened with the EALite
- (anything else?)
t-kouno
George..Brennan
« Reply #4 on: January 16, 2023, 10:05:18 pm »
Thanks, nice list, unfortunately...
no version control applied yet
no security enabled yet
no one using the API
not using files, we are using a PCS server and back end database
No one is using EaLite
At the moment I'm thinking it may be the PCS server has a lock it hasn't cleared but I don't really want to restart it and lose the evidence.
G.
George..Brennan
« Reply #5 on: January 16, 2023, 10:29:45 pm »
Further....
I exported via xmi to a local file, still locked so it looks like it's local to the model not the PCS server.
I can't see anything in the XML file that says locked.
G.
« Reply #6 on: January 16, 2023, 10:50:11 pm »
Well, that little missing info about PCS might explain things. There's a PCS board here. Good luck...
nilspc
« Reply #7 on: November 24, 2023, 01:29:20 am »
Did you find any solution for this?
We appear to have the same problem with one diagram
/Nils
nilspc
« Reply #8 on: November 24, 2023, 08:43:27 pm »
Found the solution to our problem.
If you have enabled auto refresh on a diagram it shows like locked when you right click on the diagram and the auto refresh is also exported so same behavior after import into another repository
/N
« Last Edit: November 24, 2023, 08:46:25 pm by nilspc »
M@rco
« Reply #9 on: October 08, 2025, 06:09:46 pm »
I had the same problem, and it turned out to be caused by the auto-refresh. Apparently, this feature locks the diagram. Disabling it and then restarting EA fixes the issue (the restart is necessary because Sparx locks it to your user).
Thanks, @nilspc
