Author Topic: Application Exit on project open  (Read 2561 times)
inetm
« on: January 14, 2023, 11:20:22 pm »
When I open a project, it exits after about 5 secs - closes Enterprise Architect. It does not do this with all projects just 1. Not sure what I changed, had this project for a long time so its not a new project. Any hints on what to look for or fix/repair? I do notice it open up a *.ldb access record lock for some reason.
Thanks for any help.
Re: Application Exit on project open
« Reply #1 on: January 15, 2023, 12:35:19 am »
The .ldb is just a locking info for Windoze's M$Access which eap files are. Hard to tell, but check your add-ins and turn them off all together. Likely you have one misbehaving.
« Reply #2 on: January 15, 2023, 02:16:20 pm »
The .ldb is just locking info for Windoze's M$Access, which eap files are. Hard to tell, but check your add-ins and turn them off altogether. Likely you have one misbehaving.
'Wot 'e sed!  And if that doesn't fix it, try opening the repository with MS Access and performing a compact and repair.
