Author Topic: Is there a way to choose a connector type of element on Browse Window  (Read 4265 times)
mr nobody 11
https://ibb.co/jvMrCf6 https://ibb.co/DRdqmFN
Hello Dear Users,
As I know, the connectors does not appear on the browser window. For a specific element in my MDG technology, I should be able to choose them for a property of another element. You can check the 1st link to understand better what I mean. When I click on the red circled button, it pops-up the browser window(link 2) for me so that I can choose the related elements. In this case, I want to be able to choose connectors as well. Is there a known solution for this problem, or can you suggest some if you have any in mind?
Thank you very much!
Best,
mr nobody 11
Re: Is there a way to choose a connector type of element on Browse Window
« Reply #1 on: January 18, 2023, 12:55:42 am »
No, not a solution. When we needed something like that we set the value of the tag to the guid of the connector.
Using my EA-Navigator add-in we can simply copy the guid of a connector, and navigate from/to the connector based on the tagged values.
It's not ideal, but a workable workaround for now.
« Reply #2 on: January 18, 2023, 09:58:54 am »
I also have written such an add-in for some customers. It looks in the paste buffer for a guid in either native or XML format. If so it tries to find the guid in the model and then shows the element in the browser and possible in a diagram. Works well and is not too difficult to implement.
mr nobody 11
« Reply #3 on: January 24, 2023, 08:51:04 pm »
https://ibb.co/BK9t9ZM
Hey Geert,
I used your navigator as you suggested, but I have a problem. When you check the screenshot I linked, you will see that I want to choose my pathElements. Other than connections, I choose related path elements from project browser when I click on the 3 dot button. I tried to copy and paste the guid of a connector between the elements I chosen. But, it does not allow me to type the guid there. How can choose the connector type of element, or type the guid?
« Reply #4 on: January 24, 2023, 10:38:06 pm »
You cannot choose connectors. You'll have to change the type of your tagged value from RefGUID(List) to a regular string.
