Author Topic: Weird very large numbers in t_objectconstraint.Weight column  (Read 11905 times)
« on: January 18, 2023, 12:52:52 am »
When experimenting with project transfers, we stumbled upon an issue.
Some of the values stored in the t_objectconstraint.Weight column were too large for the target database.
No upon doing a query, I found that some of these values are indeed ridicilously large. (e.g. 4E+56 and 2E+50, and so on)
When looking in the GUI I don't even see a field that exposes this weight property, so I'm a bit puzzled as how these values got there in the first place.
Does anyone have a similar issue; and possibly a clue on what is going on here?
I can of course set them all to 0 with a simple update query, but I'm afraid they will come back if I don't know where they came from originally.
Re: Weird very large numbers in t_objectconstraint.Weight column
« Reply #1 on: January 18, 2023, 01:07:32 am »
I found out the weight field is used to store the order of the constraints. If you move them up/down, the weight value gets changed.
I've experimented a bit, but I can't make it misbehave; but it might have been a bug in an earlier version that made those weird figures appear.
« Reply #2 on: January 18, 2023, 10:01:34 am »
Will the consitency check repair them?
« Reply #3 on: January 18, 2023, 04:24:44 pm »
No, I run those regularly, and they haven't touched the weight values.
« Reply #4 on: January 18, 2023, 08:35:52 pm »
Well, at least one additional info. The current statement about weight in my Inside is "does not seem to be mapped in the GUI".
« Reply #5 on: January 18, 2023, 08:39:06 pm »
Yeah, you could change that into "is named wrong and should really be named pos to be consistent with t_attribute etc..."
« Reply #6 on: January 18, 2023, 10:44:25 pm »
You can bet on that xD
P.S. When you issue a query the Weight actually is shown as a Real number. The example model has a few with weight 1.00 but most being 0.00
« Last Edit: January 18, 2023, 10:52:28 pm by qwerty »
« Reply #7 on: January 18, 2023, 11:39:14 pm »
Ah, I can now think of a scenario where that might have gone wrong.
- Get the weight value as string "1.00"
- Try to store the same value as Real, messing up the decimal point/comma notation, and end up storing the value 100 instead.
- Get the weight value as string "100.00"
- Try to store the same value as Real, messing up the decimal point/comma notation, and end up storing the value 10000 instead.
- Rinse and repeat
And that indeed checks out with the actual values found. Most of them are round numbers like 5000000000 or 2000000
« Reply #8 on: January 19, 2023, 12:08:41 am »
Yep. I always imagine the DB design troupe of Sparx as a horde of chimps hacking on keyboards. But more likely is: there's just nobody and the trainee is responsible. Who knows. But you can see: it's sick.
I have just published the update...
