Author Topic: Automatically change 'Status' to "proposed' on change  (Read 4028 times)
amacara1
« on: January 18, 2023, 07:33:04 pm »
Please, is there a way to have EA automatically change 'Status' field of an element to 'Proposed' whenever that element is modified?
By modified I mean a change in its content took place: notes, attributes, links, etc, but not added/deleted to/from diagrams.
Re: Automatically change 'Status' to "proposed' on change
« Reply #1 on: January 18, 2023, 07:58:51 pm »
Yes, but you'll need to write some add-in that runs in the EA_OnContextItemModified
Options are:
- Use a Model Addin: https://sparxsystems.com/enterprise_architect_user_guide/16.1/add-ins___scripting/modeladdins.html
- Write an EA-Matic script: https://bellekens.com/ea-matic/
- Write a full blown add-in
I would use an EA-Matic script (but I guess I'm a bit biased)
amacara1
« Reply #2 on: January 18, 2023, 08:02:06 pm »
Thank you Geert, I understand.
So there seems to be no "out-of-the-box" solution from EA (I thought it would be, as I see this as sort of element life-time managing part)
philchudley
« Reply #3 on: January 18, 2023, 08:17:45 pm »
That's correct there is no "out-of-the-box" solution.
To supplement what Geert as an alternative to an add-in which requires an installer you could have a look at Model Add-ins.
I have successfully used these to respond to EA_OnContextItemModified to monitor / update element properties.
Phil
Models are great!
« Reply #4 on: January 18, 2023, 08:37:04 pm »
Phil
Hi Phil,
Model-addins was actually my first suggestion :)
