Author Topic: Auto apply layout on a state diagram always displays bottom to top  (Read 4175 times)
BobM
Hi all,
when I apply default layout on a state diagram it always shows the initial at bottom and the final at top, is there a setting somewhere where I could reverse direction?
Thank you in advance
edit: using sparx 16.1.123
I think they renamed the ribbon settings which are currently in the manual: https://www.sparxsystems.com/enterprise_architect_user_guide/14.0/modeling_tools/layoutadiagram.html
context menu worked
« Last Edit: January 31, 2023, 08:41:55 pm by BobM »
Re: Auto apply layout on a state diagram always displays bottom to top
« Reply #1 on: January 31, 2023, 08:57:04 pm »
Yes, you can change the direction of the auto layout using the diagram properties from the context menu on the background of a diagram
Properties | Diagram | Set Layout Style | Direction | Down
There is a checkbox on this dialog to set this as default:  Set as Project Default
