Author Topic: Is there a place where I can get the diagram image files?  (Read 76029 times)
BobM
Re: Is there a place where I can get the diagram image files?
« Reply #15 on: August 17, 2023, 10:17:36 pm »
We once had the discussion in the past and the workaround suggested was to publish the report to a folder (could be automated)
You can put a Sparx HTML report into a SharePoint document library if you have CIFS or Webdav access to it.  You need to increase the files allowed in the library to about 10,000.  there is no publish directly to SharePoint.
Configure your share point credentials and connection strings under Profile Manager
Open Publish to SharePoint
Choose an added existing connection and enter the password if available
Choose a folder from Available Folders (displays all the available folders in the selected SharePoint connection)
Enter the publish settings
Select Export
