Author Topic: v16.1 - Can an item be in more thanone layer?  (Read 18239 times)
« on: February 06, 2023, 07:57:50 pm »
We are starting to use layers in some diagrams.  Do we understand correctly that a diagram object can only be in one layer simultaneously?
We found we had to create additional layers to hold the common items and specific layers to hold the items specific to that layer.
TIA,
BobM
Re: v16.1 - Can an item be in more thanone layer?
« Reply #1 on: February 08, 2023, 01:31:40 am »
I can already send you the reply sparx support will give you:
Hello BobM,
Thanks for contacting Sparx Support.
Diagram Layers is intended to view the segments of a diagram to represent any concept that is the basis for separating or grouping the elements on that diagram.
It's not possible to share elements between layers and possible to add an element to a single layer.
If you wish, you can also send the details as a feature request via the Feature request form available on our website.
https://sparxsystems.com/support/forms/feature_request.html
If you have any further questions please let us know.
Best regards,
Sparx Employee
Sparx Systems Pty Ltd
http://www.sparxsystems.com
Please do send a feature request on this as well
We currently work around this by using filters
« Reply #2 on: February 08, 2023, 09:02:33 am »
Thanks, Bob,
I'll send in a feature request.  We haven't gotten into filters yet.  Can you indicate how you use them for this purpose?  If it's easier than how we are currently doing it, we'll give it a try.
BobM
« Reply #3 on: February 08, 2023, 06:35:04 pm »
It is very dirty but it does the trick.
We use 'One of...' in the Phase field filter and fill in the phase names separated by comma.
You could use element names, or a different field.
« Reply #4 on: February 08, 2023, 08:43:19 pm »
It is very dirty, but it does the trick.
We use 'One of...' in the Phase field filter and fill in the phase names separated by commas.
You could use element names or a different field.
Thanks for that, Bob,
Filters are repository-wide, aren't they?
It's about the same amount of effort as what we're doing now.
BobM
« Reply #5 on: February 08, 2023, 08:57:49 pm »
Yes filters are repository wide, it is containable with a smaller group that uses them
What are you doing now?
Bob.
« Reply #6 on: February 08, 2023, 09:40:12 pm »
[SNIP]
Yes, filters are repository-wide it is containable with a smaller group that uses them.
Bob
An Example may help:
We have a diagram in which we want to indicate three possible views of items.  2 of those views have common elements. So we create three layers (plus those items in NO layer).
Layer 1 Only, Layer er 2 Onlyy, and a Common Layer. So selecting NO layer gives us the base view, selecting Layer 1 + Common adds the items for view 1, and selecting LLayer 2 + Common adds items for View 2.  Does that explain clearly enough?
« Last Edit: February 08, 2023, 09:43:05 pm by Paolo F Cantoni »
BobM
« Reply #7 on: February 08, 2023, 10:40:45 pm »
It does, and I imagine it might require a manual for people (re)viewing the diagrams especially on multiple phase diagrams with elements only used in transition
Sparx should add the possibility to have shared elements between layers so you only have to select one single layer
« Reply #8 on: February 09, 2023, 09:14:18 am »
[SNIP]
Yes, Bob,
We're worried bout that - that's why we asked the question.
I'll pop in the Feature Request.  Are you aware of any way to use automation to control Layer display?
BobM
« Reply #9 on: February 09, 2023, 07:16:17 pm »
From: https://sparxsystems.com/enterprise_architect_user_guide/16.1/modeling_fundamentals/diagram_layers.html
Notes
  • - If a diagram layer is selected, it will remain selected as you click out of and into the diagram
Out of experience we know this works very well especially for exporting to documents/html but we have to manually select the layer each time.
However selecting layers is currently not in the Procloud Server applications where you might expect it to be there, in this regard I doubt in the current release 16.124 there is a possible script for it.
Again, this is a feature request that would make a lot of sense for Sparx to implement it.
« Reply #10 on: February 09, 2023, 07:53:47 pm »
Notes
Interesting, When we open a diagram all layers are selected regardless of how we saved it.  Similarly, when exported to HTML all layers are selected.  I'll do some more digging and submit a feature request.
