Author Topic: Part Association relationship between Constraint Blocks  (Read 3729 times)
Doubter
« on: February 06, 2023, 08:30:39 pm »
Hello!
I am currently working on a project with EA 16, where I am trying to model a complex constraint relationship. For simplicity, I started with a simplified model that contains a "Constraint Context" block, which is connected to a Constraint Block "Constaint1" as a Part Association. "Constaint1" should be composed of two subordinate Constraint blocks "Constraint 1.1" and "Constraint1.2". In the end, the structure resembles the last image in the following entry of the User Guide: https://sparxsystems.com/enterprise_architect_user_guide/16.1/modeling_languages/sysml_constraintblock_from_equation.html
Now, when I try to draw Part Association relationships between the Constraint blocks, the following error message appears: "The requested connection is not UML compliant".
What is the reason for this and is there perhaps another way to connect Constraint blocks?
Thank you for your help!
Thomas
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
Re: Part Association relationship between Constraint Blocks
« Reply #1 on: February 07, 2023, 01:22:28 am »
I don't know the exact reason, but if you want to avoid this message, go to Start | Preferences |Links, and uncheck the "Strict Connector Syntax" checkbox.
Just try again and check if you can complete your diagram connectors.
Doubter
« Reply #2 on: February 07, 2023, 01:27:43 am »
Thank you very much, that solves it!
Best regards
Thomas
« Reply #3 on: February 07, 2023, 01:37:06 am »
It silences the message. But you're probably have a non-compliant model afterwards. If you think the connector is blocked falsely you should report a bug instead.
Takeshi K
    • Sparx Systems Japan
« Reply #4 on: February 07, 2023, 09:52:28 am »
Hello Thomas,
Try to use the build 1623 or later bacause the issue has been fixed on the build 1623.
t-kouno
Doubter
« Reply #5 on: February 09, 2023, 01:04:41 am »
Great, thank you all for your kind help!
Will ask the admin to update EA!
