Author Topic: Convert to float in sql query  (Read 8437 times)
amacara1
« on: February 08, 2023, 02:10:12 am »
I am using Version field of EA elements as float numbers. Is there a way to convert the field during an sql query so that I can compare like Version < 1.2 ?
Thank you!
BobM
Re: Convert to float in sql query
« Reply #1 on: February 08, 2023, 02:23:35 am »
WHERE
(LEFT(VERSION,1) < 1 OR
LEFT(VERSION,1) = 1 AND RIGHT(VERSION,1) < 1)
It will automatically convert to numeric
« Reply #2 on: February 08, 2023, 03:24:29 am »
There are also conversion functions to a decimal.
Their syntax depends on the database you are using.
amacara1
« Reply #3 on: February 08, 2023, 03:31:44 am »
WHERE
This does help, but I will sooner-rather-than-later reach version 10.10. Then what do I do?
amacara1
« Reply #4 on: February 08, 2023, 03:32:33 am »
I was hoping there is a thing similar to #thing# :( We are using jet 4 (eapx) and Mysql.
amacara1
« Reply #5 on: February 08, 2023, 03:40:31 am »
val() seems to work at my side.
BobM
« Reply #6 on: February 09, 2023, 01:15:25 am »
WHERE
My apologies I was lazy
REVERSE is not that performant, there might be better solutions but below is a five second tought fix for every single above 9 number
WHERE
(LEFT(VERSION,CHARINDEX('.',VERSION)-1) < 1 OR
LEFT(VERSION,CHARINDEX('.',VERSION)-1) = 1 AND RIGHT(VERSION,CHARINDEX('.',REVERSE(VERSION))-1) < 1)
« Last Edit: February 09, 2023, 01:21:08 am by BobM »
amacara1
« Reply #7 on: February 09, 2023, 03:07:26 am »
Thank you, BobM for your time. Pittyfully, CHARINDEX did not work on my jet 4 :(
But, I solved my need with val(), which is ok for now.
« Reply #8 on: February 09, 2023, 08:57:52 am »
For MS Access you need INSTR()  (The CHARINDEX equivalent)'
