Author Topic: SOLVED: Adding and removing space to and from a canvas  (Read 85103 times)
MWHBS
Re: SOLVED: Adding and removing space to and from a canvas
« Reply #15 on: May 09, 2023, 07:03:32 pm »
Dear Geert
Thanks, but perhaps I was inprecise in my explaination. I am not selecting individual elements and try to move them, but I have a diagram with pools in it. And in these pools I have several items like tasks and and notes and so on. And when I then go to the context menu of each pool, mark it as non-selectable and then activate the sweeper tool, everything is moved including the non-selectable pools. This is confusing for me. Do you have a solution suggestion?
Best regards
Martin
« Reply #16 on: May 09, 2023, 07:13:22 pm »
You can multiple select element by dragging the mouse starting at an empty space on your diagram.
Using Alt-Drag sortof does the same thing as the sweeper tool, but it leaves the non-selectable elements alone.
I've never actually used the sweeper tool; somehow I never really needed to I guess ???
MWHBS
« Reply #17 on: May 09, 2023, 07:22:30 pm »
Dear Geert
I must be doing something wrong. I wish I could send you a demo picture here. Therefore I can only tell you that I set the pool to non-selectable and even with alt-drag it is moved for unknown reasons.
Best regards
Martin
MWHBS
« Reply #18 on: May 09, 2023, 07:24:42 pm »
Trying a different angle: Is it possible to somehow unlink elements from the pool they are in? Because I guess that the moved items within the pool are dragging the pool with them.
BobM
« Reply #19 on: May 09, 2023, 07:35:38 pm »
Sweeper actually moves the pool and lanes as well regardless if it is selectable or not
Easy to reproduce:
1) Make a new diagram with a pool and one or two lanes
2) Add elements to the lanes
3) Set pools and lanes as not selectable
4) Sweep
5) Sigh at the result
Knowing Sparx
If you would file a bug my guess they will say working as intended but you can always try
« Reply #20 on: May 09, 2023, 08:37:36 pm »
True, alt-dragging indeed moves the pool as well, I tried it and it seemed to work, but I must have done something wrong when testing before.
It does work with multi-selecting elements though, so that might be a workaround
MWHBS
« Reply #21 on: May 10, 2023, 09:22:52 pm »
Thanks! That is unfortunate, but at least I know that it's not me, but a lack in functionality. And do you know if an element can be unlinked from a pool?
BobM
« Reply #22 on: May 10, 2023, 09:39:14 pm »
You can just drag it out of the pool/lane/parent element in the browser window
