Author Topic: Element shadows Off, how?  (Read 16777 times)
José Farinha
« on: February 16, 2023, 06:05:48 am »
Anybody knows if there is a way to switch off the shadows behind classes with EA 16.1?
I could swear I've done that before using Preferences. Now, all I can find is a check box in
   Preferences -> Diagram -> Themes -> Applied styles,
which I already unmark, but shadows are still there.
I've considered setting the shadow colour to white, but would like to do it the proper way.
Thanks for your attention.
BobM
Re: Element shadows Off, how?
« Reply #1 on: February 16, 2023, 07:04:40 pm »
It could be the diagram properties of the specific diagram you are watching have overruled your global settings.
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« Reply #2 on: February 17, 2023, 03:13:04 am »
You are right. I have just tested it in version 16.1 and even if I uncheck, the shadows are still present.
I suggest you report it as a bug.
workingmatt
« Reply #3 on: March 13, 2025, 02:01:27 am »
This is still a bug in that turning off shadows in global or diagram preferences doesn't work, however, if you draw a custom shape with shapescript including noshadows=true; there will be no shadows.
Takeshi K
    • Sparx Systems Japan
« Reply #4 on: March 13, 2025, 09:42:10 am »
It seems that everyone in this thread use the wrong setting.
The shadow on/off is Diagram | Appearance | Element Shadow ON in the Preference dialog.
The mentioned setting is for your own theme.
This is not a bug, the above correct setting works perfectly, both on the older versions and latest.
t-kouno
