Author Topic: Insert related elements refresh  (Read 7733 times)
BobM
« on: February 21, 2023, 07:55:26 pm »
I had a mail from Sparx indicating they are having problems reproducing the bug where you click an element and insert related elements it shows all related elements but when you click refresh some elements vanishes (eg. flows to relations on a BPMN activity, application function realizes an application component, etc...)
I use procloud 5.123 but can easily reproduce this on a local project
As Sparx indicates they are having issues to reproduce this, is there a setting somewhere that causes this behavior?
Re: Insert related elements refresh
« Reply #1 on: February 21, 2023, 08:21:39 pm »
Hi Bob,
We ran into this SAME problem yesterday on our repository - whilst trying to demonstrate what a neat feature it is!  No Pro cloud just EAUI.  SQL Server, b1624.
It's not just you...
[Edit: just retried and it seems to work correctly.  Also on .eapx local file]
« Last Edit: February 21, 2023, 08:39:46 pm by Paolo F Cantoni »
« Reply #2 on: February 21, 2023, 08:23:35 pm »
I found that in many cases you have to spoonfeed Sparx support if you want your bugs to be fixed.
Provide them with a model, and an exact scenario on how to reproduce the issue.
It's a lot of work, and I often feel like it shouldn't be my work, but I need those bugs fixed as well... so I do it anyway.
BobM
« Reply #3 on: February 21, 2023, 08:32:34 pm »
Hi Bob,
The workaround I do is uncheck one of the filter groups (uncheck all connector types or uncheck all element types) then hit refresh
The workaround isn't optimal so this should be fixed, I'm happy to read other people have stumbled upon this easy to reproduce issue.
BobM
« Reply #4 on: February 21, 2023, 09:20:16 pm »
So its inconsistently correct?  8)
Did you change anything in comparison to when you gave the demonstration?
« Reply #5 on: February 22, 2023, 09:15:50 am »
[Edit: I just retried, and it seems to work correctly.  Also on .eapx local file]
We're making changes all the time, trying to get to the bottom of other issues that are currently impacting us.
However, it did occur on at least two machines at more or less the same time.
