Author Topic: How to import vsdx files  (Read 16290 times)
MWHBS
« on: February 24, 2023, 08:30:50 pm »
Hello everyone
I am using EA 15.2.1559 and I want to import a Visio .vsdx diagram. I found this, but I am afraid that the website is i) describing a different version, because I see no extension menu and ii) that I do not have the permissions to install a new extension due to corporate IT restrictions.
Do you see an easy way to import vsdx diagrams?
Best regards
Martin
Sunshine
  • Its the results that count
Re: How to import vsdx files
« Reply #1 on: February 25, 2023, 09:23:08 am »
You need to down load the visio MDG importer. https://sparxsystems.com/registered/reg_ea_down.html. In order to do that you need to have a login which you are given the first year after purchasing Sparx EA then its renewed when you purchase support.
Happy to help
« Reply #2 on: February 25, 2023, 09:57:26 am »
Ask your boss to get operator rights in order to install something. Or have someone do it on your behalf. Not sure if you will be too happy with the Visio import, though. Visio is a primarily a drawing tool and not a modeling tool. It's like you want to get a statue from photos taken of it.
Sunshine
« Reply #3 on: February 26, 2023, 06:39:03 am »
One more thing is you need visio too otherwise the visio importer won't work.
Happy to help
MWHBS
« Reply #4 on: February 27, 2023, 04:13:29 am »
To everyone: thanks for your advice.
But when I have to have visio for the importer to work then I won't need the importer anymore. I just need a way to get those old diagrams in an editable format. :(
Sunshine
« Reply #5 on: March 01, 2023, 05:28:04 am »
Try libre office draw it can import visio.
Happy to help
MWHBS
« Reply #6 on: March 01, 2023, 06:24:52 pm »
Thanks, but I have no permission to install another office suite. This is regulated by corporate IT governance.
ea0522
« Reply #7 on: March 01, 2023, 07:07:20 pm »
« Reply #8 on: March 01, 2023, 07:11:41 pm »
Or try a web based free Visio viewer:
https://www.microsoft.com/en-ww/microsoft-365/visio/free-visio-viewer
I think the OP specifically needs to be able to edit a Visio diagram. Viewing can be done with a browser as well IIRC.
Sunshine
« Reply #9 on: March 05, 2023, 06:22:35 am »
What and they don't provide visio? Can you not put in a request for software. If not then it sounds like you don't have an environment fit for purpose.
Happy to help
MWHBS
« Reply #10 on: March 06, 2023, 06:49:36 pm »
I would say it is part of moving away from visio. If you give access to it, people will keep using it.
Sunshine
« Reply #11 on: March 06, 2023, 08:29:20 pm »
Well if you want to use diagrams in visio format then you should have migrated them before removing visio from the environment. The situation may not be of your creation however the fact is you need to find a solution around it. If you want to port visio diagrams to sparx you need visio  mdg visio importer and sparx EA.
Happy to help
« Reply #12 on: March 06, 2023, 08:41:10 pm »
That, or you simply recreate the diagrams in EA.
To be honest, often that is the better solution. Importing stuff like visio into EA creates a lot of garbage that needs cleaning. Often it even takes less time to recreate the diagrams than it does to clean them after importing.
Sunshine
« Reply #13 on: March 06, 2023, 08:54:04 pm »
That is true what Geert says. Some visio diagrams import quite well but a lot don't. So a fair amount of manual tidying up is required. I often use javascript to automate the tidying up. However not everything can be automated.
Happy to help
MWHBS
« Reply #14 on: March 07, 2023, 08:43:14 pm »
I hope that I will have such skills one day. Sounds good.
