Author Topic: Change Management, Baselines and Release Notes  (Read 7177 times)
ducatiross
« on: March 01, 2023, 10:38:00 pm »
Hi everyone,
I am working on a project where we need to release a new version of our model at the end of every sprint. At the end of a sprint, I use Package Baselines to create a new baseline for that period. As well as a copy of the model, we need to provide a set of release notes that explain changes to the model since the last baseline taken at the end of the previous sprint.
I am trying to work out the best way to do this.
I can use the Baseline Compare feature in EA  to get a diagrammatic view of changes but this is not easily shareable with people who do not have access to Sparx EA.
I can export this to an XML file, but this is not very human-readable and requires a lot of editing to filter out unnecessary data.
Has anyone got a good way of identifying changes between baselines and making this generally available to people outside of EA ?
Matthew
Re: Change Management, Baselines and Release Notes
« Reply #1 on: March 02, 2023, 03:02:14 am »
Some of my clients are using Word compare to highlight changes in the documents generated by EA.
We also have a way to tag elements with Change objects so we can build a type of "release notes" from that info.
jfzouain
« Reply #2 on: March 02, 2023, 03:07:13 am »
Geert has the correct answer, use the Baseline compare.
Generate a document for both sprint and use the word compare.
I have use it and is better than XML file.
Best regards
Jose Zouain
ducatiross
« Reply #3 on: March 02, 2023, 03:34:18 am »
Thanks Geert and Jose, I will try that.
It's seems a bit naff though, that you have to output two documents and then use another software company's product to find changes in your model. Come-on Sparx, come up with a better solution ! Some form of externally accessible tree-structure output that mimics the Baseline Compare in EA would be a start.
