Author Topic: Cannot export DB: Index or pri key cannot contain a Null value in t_objectscenar  (Read 4657 times)
amacara1
Hi!
I am faced with this error (tens of times) when exporting my_sql DB to file, using EA16. Used to work fine a couple of hours ago :)
I noticed I have a row with empty ea_guid in t_objectscenarios. If that could be the root cause of my error, can I delete this row from the table, somehow? (tried delete, does not seem to work)
Thank you!
Try a consistency check.
amacara1
I ran Integrity check, no luck.
So then, report a(nother) bug...
