Author Topic: Something similar to VBA  (Read 9159 times)
MWHBS
« on: March 05, 2023, 07:34:40 am »
Hi
I just wanted to ask if there is something similar to VBA in Office that can be used to write one's own modifications for EA? Is there a starting point iike a tutorial ("Dear beginners, macros/extensions/whatever are built in the following programming language and you can use the following example to render a hello world message" etc)?
Best regards
Martin
Re: Something similar to VBA
« Reply #1 on: March 05, 2023, 08:16:17 am »
Well, you can use anything. Personally I use Python for lots of reasons. But that's up to everyone's taste. WSH works (I used that once), Perl (ditto), Java (well, not used but I know that people use it). You can as well go with compiled code (whatever you wish should do).
If you need a guide to EA's API you can look into my Scripting book. I once wrote that after struggling with what Sparx provided.
« Last Edit: March 05, 2023, 08:47:25 pm by qwerty »
« Reply #2 on: March 05, 2023, 07:44:28 pm »
You can use the internal scripting feature.
In the manual there are a few "hello world" type examples.
More complicated real-world stuff: https://github.com/GeertBellekens/Enterprise-Architect-VBScript-Library
MWHBS
« Reply #3 on: March 06, 2023, 06:56:02 pm »
Thank you. Sounds good. If I could choose freely I would use Python. Where do I find that scripting book that you spoke off?
MWHBS
« Reply #4 on: March 06, 2023, 06:56:43 pm »
Thanks Geert
I will also take a look at this.
Best regards
Martin
Sunshine
  • Its the results that count
« Reply #5 on: March 06, 2023, 08:42:49 pm »
Depends on problem you are trying to solve.
For automating some tasks I use javascript which is built in. Note python support doesn't come out of the box. There is vbscript and jscript also out of box but they are becoming legacy.
If I need to extend functionality with a User Interface then I use c# with .net.
If you simply want to add extra attributes to elements in an existing modelling language like archimate the create an mdg.
Well there are a few options you can look into further. More details can be found in pdf library https://sparxsystems.com/resources/user-guides/16.1/index.html
Happy to help
MWHBS
« Reply #6 on: March 07, 2023, 12:29:40 am »
I am sorry that I bothered you. Under tools there is only the Script Library and the Javascript console. I do not see a menu entry "Scripting". Most probably it has been deactivated. Would fit with the rest.
In  the library both, new group and new script, are grayed out ...
« Reply #7 on: March 07, 2023, 12:36:08 am »
It's the script library you should be lookign at.
If you can't create any new scripts, that can be either a permission issue. (which you shouldn't encountered if you create a new local model and test it there), or a license issue.
You need at least the corporate edition to be able to use scripting.
