Author Topic: How to select tag values for operation parameters  (Read 4416 times)
heydukr
« on: March 07, 2023, 01:54:41 am »
Hello, I've defined t_operationparams items in EA as a detail row for t_operation row connected via OperationID realation key. I've add a tag value to the operationparam. I'm able to select the operationparam:
SELECT * FROM t_operationparams a  where a.Name = 'IP_ADDRESS'
Will You please give me an advice how to select matching tag to this param? And what raltaion key shall I use?
SELECT * FROM `ea-integration-platform`.t_propertytypes a where a.Property = '...'   - is a possibility but I miss a raletion key
Thank You
Re: How to select tag values for operation parameters
« Reply #1 on: March 07, 2023, 01:56:36 am »
Parameter tags are stored in t_TaggedValue IIRC
« Reply #2 on: March 07, 2023, 05:18:19 am »
Almost. It's t_oparationtag
« Reply #3 on: March 07, 2023, 05:59:40 am »
For parameters? Are you sure?
In my parameter wrapper class I have this:
        protected override string getTaggedValueQuery(string taggedValueName)
            return @"select tv.PropertyID from t_taggedvalue tv
where tv.TagValue like '" + taggedValueName + "' "
                + " and tv.ElementID = '" + this.uniqueID + "'";
« Reply #4 on: March 07, 2023, 09:26:33 am »
My, bad. I attached it to an operation :-( But now, how can a parameter be tagged?
« Reply #5 on: March 07, 2023, 07:26:12 pm »
EA lets you do it.  Select a parameter for an operation (I used the Primary Key operations on a Table), then add the tag.  As Geert said, they end up in t_taggedvalue.
« Reply #6 on: March 07, 2023, 07:40:52 pm »
I guess, since you mention it, that this is only possible for database opertation parameters (I dealt with that only many years ago). Normal classes do not offer creation of tags.
« Reply #7 on: March 07, 2023, 08:15:13 pm »
They do. It works the same as with associationends.
On the operation properties Tags, there are sections for all parameters. If you click on a parameter and then use the "add new tag" button, it adds a tagged value to the parameter.
« Reply #8 on: March 07, 2023, 08:52:40 pm »
You are right (as always), Geert. I never was aware of that... (the way it works is EAUI, also as always).
heydukr
« Reply #9 on: March 07, 2023, 11:07:49 pm »
Thank You very much, I've got it:
SELECT b.Name AS param_name
         , a.Notes  AS param_tag_value
   FROM  t_TaggedValue a
           , t_operationparams b
  WHERE a.TagValue = 'TAG NAME'
      AND a.ElementID = b.ea_guid
« Reply #10 on: March 07, 2023, 11:39:14 pm »
Yes, but I would write it differently:
SELECT opr.Name AS param_name
,tv.Notes AS param_tag_value
FROM  t_TaggedValue tv
INNER JOIN t_operationparams opr on opr.ea_guid = tv.ElementID
WHERE tv.TagValue = 'TAG NAME'
This way you differentiatie between your join criteria and your selection criteria
heydukr
« Reply #11 on: March 08, 2023, 07:12:19 pm »
You're right, thank You
