Author Topic: MDG: Initial value for fields like phase/Status on creation  (Read 3904 times)
amacara1
« on: March 08, 2023, 01:30:21 am »
I have added stereotypes to my MDG. Is there a way to define an initial value for fields like Phase/Status to be used when adding elements of the new stereotype?
Re: MDG: Initial value for fields like phase/Status on creation
« Reply #1 on: March 08, 2023, 01:34:31 am »
You mean the standard EA fields?
You can't define that on the MDG level.
For status however there is a default status you can define yourself in EA (for the whole model)
For the other fields, I would check if you can do something with the model template package.
If that is not OK for you, you might want to consider adding these fields as tagged values in your stereotype instead of using the standard fields.
